smart link failed to connect
Hi,
I can't connect and getting this message. It was working perfectly until now.
thanx, Stuart
    this should help explain things.
    Or, just reboot your radio and your router and see that fixes it.
  • k3qh
    k3qh Member ✭✭
    I got it registered but still will not test.
    Registering and passing a test are 2 different things.
    The first is used to identify you. The test makes sure the right communication packets are making by your router to the radio. If the plumbing is busted, it will fail a test.
  • k3qh
    k3qh Member ✭✭
    Mike thanks,
    so it is possible my router can be blocking the communication?
