Maestro C - technical notes
I am sharing some key technical points for those interested.
Shipping is still by year end 2023, but it is still a moving target, but we are working overtime to get it done. Once we start shipping, they will move out in a hurry.
If you have a unit on order we have already reached out to you a few times. If you haven't heard from me, please check your spam folder.
Connectors
- HDMI display out - Type A
- 1920 x 1200 WUXGA Display
- RJ45- Ethernet 100/1000 mb/sec
- CW Key - ⅛” TRS
- Powered Speakers - ⅛” TRS 3 watts
- Line Out - ⅛” TRS
- Push to talk (PTT) - ⅛” TS
- Headphones - ⅛” TRS 16 or 32 ohms
- 24V DC 4 Pin D - PD-40V
You'll notice the connector layout and the 24V DC connector.
More to come and some things are still subject to change.
That's an interesting battery arrangement; looks to be a very specific size and fit. Considering how quickly manufacturer technology is changing now-a-days I wonder how confident FRS is that these size batteries will be available for the long term, in 5 or 10 years?
Butch, KF4HR
Assuming the absolute worst, that all batteries are dead and no new ones are available, you could still use an external battery or just plug the unit into a wall outlet.
Yes, with the AC adapter that is shipped with it
The battery finds applications across various industries, giving us hope for its longevity. Nonetheless, one valuable lesson we've all learned is that there are no certainties when it comes to the future.
Rats! No Crystal ball???
Not ideal LAN and HDMI cables orientation, Need to use 90 degree adapters that cables will not hang on on the side of Maestro.
Often, when you see these it is a matter of just where things will fit based on the internal construction. It may not have been the first choice in the design, but as you assemble the puzzle, that is what is left.
We are selling a 90 degree HDMI cable kit, but we may also have to add a 90 degree CAT kit as well.
When I ordered the Radio Sport headset, I ordered the cable for the Maestro, that I'm waiting for. Looking at the picture of the connections, I'm not sure it will work with the Maestro. I see the HDST connection and I'm assuming that's for the 4 section jack(?). Do I need to get another cable?
Mike are the specs set in stone or is Bluetooth still being considered? It certainly would give the "C" much more Flexibilty, pun intended.
Here is what was shared via email to those who currently have a new Maestro on order. Some other parts have been removed.
Will the original Tilt Feet (for earlier Maestro models) work?
Originally, the Maestro A, and B tilt feet were not going to fit as we advised some of you.
We have found that with some adjustments these feet can fit, however, they will be a bit taller and not spaced as wide.
Will the FHM-3 from the FLEX-6000 series radio connect to a Maestro C?
No. The Maestro C uses a ⅛” TRRS model of connector for the Microphone in order to allow TRRS headsets to work with the Maestro C.
FlexRadio plans to market an optional cable that can be connected to the Maestro C and the Microphone Head of the FHM-3.
What is included with the Maestro C?
- Maestro C
- AC Power Supply
- Fixed Mounting Feet
- LAN Cable
- Quick Start Guide
Is a battery required to operate the Maestro C?
No
When do I pay for my Maestro C order?
FlexRadio will contact you before shipping your Maestro C.
What Version of SmartSDR is required for Maestro C?
SmartSDR v3.6.x or v2.11.x or higher once they are released which will be prior to your Maestro shipping.
Note: When using SmartLink to connect to your radio, you can update the Maestro remotely without issue. What you can't do is update the Radio firmware remotely.
Will the original screen cover fit a Maestro C?
Yes.
Can I use my Bluetooth audio devices?
Bluetooth capability will not be supported on the initial release.
We are actively evaluating the performance and interoperability of Bluetooth for the Maestro and will provide updates via the newsletter as things progress.
What connectors are provided on the Maestro C?
- RJ45- Ethernet 100/1000 MB/sec
- CW Key - ⅛” TRS
- Line Out - ⅛” TRS
- Mic / Headphone - ⅛” CTIA TRRS 16 or 32 ohms
Hello:
Mouser appears to have this battery for considerably less ($118.) That is, of course if it's the same battery and will fit in the Maestro C. To be honest, I just copied the battery information from the specs below and pasted it into a web browser and Mouser came up.
Can anyone verify whether the Mouser battery will fit in the Maestro C?
https://www.mouser.com/ProductDetail/RRC-Power-Solutions/RRC2054?qs=C8aJjQqBHT0u5M3Buo4uYg%3D%3D
I don't think that is the same battery as we are buying them in bulk and we aren't marking them up at all. That battery looks like it is 1/2 the size. Look for the RRC2054-2
I would not jump the boat just yet and order batteries. But, if we find them cheaper, we will pass that on.
https://www.mouser.ca/ProductDetail/RRC-Power-Solutions/RRC2054-2?qs=W0yvOO0ixfHzDy4VaSxYMA%3D%3D
Mike is right BUT?
There are different version (Slightly different part numbers) of those Batteries that you can purchase from many locations and I seen some with the same larger footprint that has different Watt Hour Capacity And Voltage's, I think this is the key to finding the correct Battery, The one on Mouser is 99 Wh. and 14.4Volts. The ones shown in the Maestro Survey picture are 95.4Wh @ 14.4 volts. BUT the Description is WRONG in the survey from the Survey which says " RRC2054 (4S1P) with 15.0V / 3200mAh / 48.0Wh - $215".
It is important to get the correct EXACT battery number, I think I remember seeing the differences is shown with the Suffix on the part number when I looked a few weeks ago.
I think I even seen some on EBAY and Amazon if you dare buy from them.
SO WHICH IS IT??? The Battery in the picture or the NON -2 battery shown in the Description "RRC2054 (4S1P) with 15.0V / 3200mAh / 48.0Wh - $215" ???? These are TWO totally different Batteries.
Thanks Bret
I noticed the exact same thing yesterday. In house, I wanted to actually physically see installed on the prototypes we have. :)
*** Update ***
My mistake in the FAQ wording and I should have caught this.
When using SmartLink and a Maestro, you CAN update the Maestro remotely.
What you can't do is update the Radio Firmware with a Maestro remotely.
I will update the FAQ above and my apologies for the confusion.
Is the maestro C touch screen a separate unit or another 8” tablet with built in Dell PC like the A or B models?
Bob KC9RF
The Maestro C is a Touch Screen Display. It is not a tablet.
Mike,
Are there any changes to Smart Control with Maestro C? I use a remote desktop and would like to know if I can use MIC input and CW input (using a straight key) on the Maestro-C in Smart Control that is connected to and controlling the slices etc on the SmartSDR client running on the remote PC.
This is from the current 3.x Maestro Manual, Section 9.5.9 What you Cannot Do in SmartControl:
• The Maestro Mic input is not available while in SmartControl Mode.
• The Maestro internal speaker is disabled when in SmartControl mode.
Chris de WX7V
Hi Chris
Unsure just yet. As far as I know, the functionality at this time is identical. Once we get that running, we will then look at new features.
We have a living document here:
I, for one, am pleased that shipping has been pushed back to January 2024. You see, when I ordered the Maestro in February, I made a deal with myself: I'd reward myself with a Maestro after learning morse code, knowing I'd have at least until fall 2023 to do it. I overran the clock a bit, natch, but I at least now know all the characters (albeit at 5/20 Farnsworth). Since I've been granted another month's reprieve, I may get to 8/20 at 95% copy, at which point I'll feel like I've earned a shipping notice. 😂
But seriously ... thank you for prioritizing quality over speed, and for hanging in there through some tough years for manufacturing (and everything else).
Our Alpha testers are now playing with them. Canada Customs is holding on to mine for some reason. :)
@Mike-VA3MW When you get your unit to test, I'd really like to know if the CW input on the Maestro can be used to key the remote FlexRadio when the the Maestro is in SmartControl Mode. This would be a great solution for my remote straight key operations. RKI is good but finnicky.
PS - The manual clearly states that the Mic input is not available while in SmartControl Mode, but does not say if CW input is available or not.
Chris de WX7V
Hi Chris
I will test that, but if you can't do it on the earlier Maestro's you won't be able to do it on the new one.
I can attest that the CW keying DOES in fact work on the Maestro (I have a B) while in Smart Control mode.
Charlie KB8CR
Charlie, Thank you - but to be clear on the answer, the CW input on the Maestro does key the remote radio in Smart Control mode?
I just tested it on 3.6.3 (internal version) and yes, CW does work on the Maestro with the Maestro in SmartControl. Once I get my new Maestro, I will test it as well.
Thanks for asking this as I had to go try it.
Mike a while back I ask about the Battery for the Maestro C and at that time you were unsure if it took the the smaller RRC2054 that is about 4" long or the larger RRC254-2 that is about 6" long and having heard nothing about it, I'm still wondering about which battery it takes.
Thanks a lot Mike and hope the Maestro C is released soon to the rest of us, It would be a nice Birthday present.
VESA mount>? I see 4 holes?
Would be handy on a swing arm.
Mouser says the RRC2054-2 battery (specified for the Maestro C on the Flex website) is 150.4 mm long.
Hi Mike, this does only work for CW , right? Not for SSB?
Volker
- 387 Community Topics
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 809 Peripherals & Station Integration
