pgxl and tgxl access code for remote operation
hi,
Do I pick any code as an access code for remote operation or is there one that has been assigned somewhere? I did just pick four numbers and saved it however I still can't connect. Also once I saved it that box in the settings page disappeared, how would I get it back to pick a different code? I'm really confused,
thanx, Stuart
You pick your own and set it up on the Local connection.
Mike, thank you for the really quick response. I understand. Is there a way to change the code once entered because the remote access auth code box disappeared after I entered one.
Yes, you just type over it on the Local client to the PGXL (and TGXL -- something).
It shouldn't disappear as that screen shot was from mine PGXL client.
What version of the PGXL client are you using?
I'm using version 3.6.24, I just updated today however
this is my settings and the remote access auth code field disappeared after I entered a random code and saved it.
mike, I upgraded just as you said and the upgrade installed and failed 3x. I can not get it to run. If I click on software it just goes back to asking me if i want to install the latest firmware. clicking on the ? shows I have it installed.
Please open a support ticket
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
