PGXL/MARS with non flex radio
Anyone know if the PGXL will operate MARS with a Non Flex Radio?
  • John WA7UAR
    John WA7UAR Member ✭✭✭
    I don’t know why it wouldn’t Larry.
    The PGXL simply increases the power output levels from the input it receives. As long as your non-flex radio is physically capable of transmitting on MARS frequencies then the PGXL should just pass it all through to your tuner and/or antenna. Am I understanding your question correctly?
    Yes, it will. RF performance specifications are only for Amateur bands.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Larry, What particular frequency are you trying to use and those of us who have the PGXL and who are on MARS can check it into a Dummy load and see if ours is doing the same thing, and of course as Mike said is your Radio is capable of using those frequencies it should work.
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    Thanks for the replys, I don't have all the details but a friend that has a IC-7610 an is a AF MARS member is in the market for a new amplifier.
