Now what? High swr and error message
I just put an Antenna Genius in line and set it up. Initially everything seemed to working fine. Now the amp is showing high swr and I get some error message where the AG utuility should be. Not sure what is happening.
The message you posted from the AG means it lost its network connection.
Often, this can be related to RF getting into a network switch and causing a loss of TCP communications.
That might be the first place I would look.
I rebooted everything and this message popped up in the AG box
Well I took a chance that maybe the AG didn't like the Power supply. Seems to be working now. I will check back in a hour and see if it is still working.
Thanks. The change of power supply seems to have remedied the problem (of course there is always tomorrow) and yea I suspect rf might have been disrupting the AG via the supply. If something else pops up I will post an update.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
