Now what? High swr and error message
Mike Member ✭✭
I just put an Antenna Genius in line and set it up. Initially everything seemed to working fine. Now the amp is showing high swr and I get some error message where the AG utuility should be. Not sure what is happening.
    Answer ✓
    The message you posted from the AG means it lost its network connection.
    Often, this can be related to RF getting into a network switch and causing a loss of TCP communications.
    That might be the first place I would look.
  • Mike
    Mike Member ✭✭
    I rebooted everything and this message popped up in the AG box
  • Mike
    Mike Member ✭✭
    Well I took a chance that maybe the AG didn't like the Power supply. Seems to be working now. I will check back in a hour and see if it is still working.
  • Mike
    Mike Member ✭✭
    Thanks. The change of power supply seems to have remedied the problem (of course there is always tomorrow) and yea I suspect rf might have been disrupting the AG via the supply. If something else pops up I will post an update.
