loading profile into panadapter
Running 6400M ver 3.5.9. SSDR is not running on the PC.
I have two pan/slices running on the radio, one on 20m cw and one on 15m ssb. I see a spot for 15m cw that I would like to work. I make sure that slice b (the 15m slice) is the tx and active slice. Then I try to load a 15m cw profile into slice b.
What happens is that the profile gets loaded into slice a and slice b disappears.
Am I doing something wrong? Or is that the way it's supposed to work?
Fred, K0FG
Fred
Is this a global profile or a tx profile?
Global profile
Global profiles save the whole layout, you can't load a global profile into a slice. When you load another global profile it will load up what ever you had in slice A and B at the time you saved it (even if nothing was in slice B), not just the slice you would like to change..
I understand, thanks for the help. I did create a global profile with 20cw and 40cw, saved it and it loaded just fine. Now I know how to do it.
Fred, K0FG
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
