IOS Smart SDR sometimes never opens
Hello. I notice sometimes when I launch THE IOS Smart SDR to connect. On my LAN or WAN. The app never opens and the pin wheel spins and spins. So I have to close and relaunch the app. Sometimes two or three times. Has anyone else seen this. It happens over WiFi or AT&T cellular. (Both) It will say setting up smartlink then done. But never opens.
Thank You.
Hi James
You may need to reach out to the Marcus (author) for this one.
I did but with the Smart link down there not much I can do.
hi.. James
First make sure you have done an update data . this can be found in the settings
if you are NOT running remote
Then go into setting and turn off smartlink....
after you have done this, you will be able to access the radio over the LAN
when smartlink gets back online in a more stable configuration ,
then you can re-enable smartlink in the settings
I have flex 6600m and use both iphone as well as ipad and Macs...
i can easily access the 6600M over my house LAN even now with smartlonk disabled in the ios app
Paul K3SF
I notice the same behavor on my IMAC too.
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
