SunSDR2DX and PGXL
Slawomir
Hi everyone,
has anyone worked with SUNSDRDX2 with PGXL amplifier? I want to make such an attempt. I am asking for advice on how to do it?
73!
Slawomir
Hi
Did you have any luck connecting SUNSDRDX2 and PGXL ?
73es
De LA4JGA Erik0 -
I looked at the manual, and it looks like there is an RS-485 out from the 15 Pin connector on the back. What I can't tell is what data is being sent via RS-485. You will need an RS-485 to RS-232 level converter and hopefully it is in Kenwood CAT format. I recommend you contact Sun directly.
Review section 3.4 on the SunSDR Manual?
Other than that, you can just use an RF Cable but you will have to make your own PTT cable from the 15 pin connector and run the amplifier in RF Sense mode.
Sun did not make this easy at all if you are a plug and play person.
Good luck, 73, Mike va3mw
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
