IOS Smart SDR sometimes never opens
Hello. I notice sometimes when I launch THE IOS Smart SDR to connect. On my LAN or WAN. The app never opens and the pin wheel spins and spins. So I have to close and relaunch the app. Sometimes two or three times. Has anyone else seen this. It happens over WiFi or AT&T cellular. (Both) It will say setting up smartlink then done. But never opens.
Thank You.
    Hi James
    You may need to reach out to the Marcus (author) for this one.
  • KG5PTE
    KG5PTE Member ✭✭
    I did but with the Smart link down there not much I can do.
  • K3SF
    K3SF Member ✭✭✭
    hi.. James
    First make sure you have done an update data . this can be found in the settings
    if you are NOT running remote
    Then go into setting and turn off smartlink....
    after you have done this, you will be able to access the radio over the LAN
    when smartlink gets back online in a more stable configuration ,
    then you can re-enable smartlink in the settings
    I have flex 6600m and use both iphone as well as ipad and Macs...
    i can easily access the 6600M over my house LAN even now with smartlonk disabled in the ios app
    Paul K3SF
  • KG5PTE
    KG5PTE Member ✭✭
    I notice the same behavor on my IMAC too.
