SmartSDR and KPA/KAT500 power/swr
DDUtil will do what you want.
73 Martin
To expand om Martin's comment, you will need to run DDUtil on a computer local to the radio. There are two serial ports on the KPA 500. Plug the one marked PC into your PC running DDUtil, and the other into the back of the Flex. Go to the USB Cables screen in SmartSDR and set up the cable to the amp.
Set up DDUtil for the port you have the KPA 500 connected to.
To see DDUtil and control the amp remotely, use AnyDesk, TeamViewer or some other remote control PC software.
I am away from my shack right now or I would have provided some screen shots. If you get stuck, be sure to post back here. If you get really stuck, I would be happy to do a Zoom or Skype session to help you out.
I used to run my KPA500 connected to Nodered on a PI and then I could watch it from any browser.
Getting things up and running on NodeRed is not hard at all. And, there is lots of ham operator support for it.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
