SmartSDR version clean up.
I just updated my 6400M to 3.5.8. All went well no issues with up grade.
Question:
When up grading a 6400M to new version. I see many older version listed still available to select. Is there way a to delete these old version of SmartSDR off the M model radio, so it might clear up some space on the micro SD card or at least remove the pointer file so the card can write to that space again?
Shawn
Ve3xyy
As far as I know, there is no way for the user to ' clean up' the listed versions on Maestro/"M" models. But that usually happens from time to time under Flex control if the Maestro is connected to the internet. Mike just posted a notice on the subject.
AL, K0VM
Remember the Maestro (and also the M models?) are designed for connection to MULTIPLE radio servers, each of which may be on a different version.
I would like the selection screen, especially when only one choice, to have the radio version there as a default with the "Versions" button for changing the default.
hello
the new update fixes many bugs
but the recorder keeps giving problems when you record
lack of memory is heard with a broken voice
73"
Looks like version 2.2.2 will clean off the old versions on M and Maestro and then load current.
SHawn
ve3xyy
On the M models, there is a 32G hard drive. All the versions of SmartSDR might take up maybe 1Gb, so there is no concern for space due to SmartSDR versions.
All version 2.2.2 does is clean up a mistake Microsoft made. It does not touch any SmartSDR files.
Afternoon mike, I am running V2.10.0. do I need to go back to the V3.5.8 ? radio is: 6400M, computer is a Dell 3620 with windows 10 pro.
If you are licensed for version 3, you might as well upgrade to 3.5.8. The only difference is that v3 gives you MultiFlex and SmartControl.
Since you have an M model, SmartControl is a distinct advantage. It allows you to operate with SmartSDR (mouse and keyboard control, full size panadapter and waterfall) while simultaneously using the knobs and buttons on the front panel.
MultiFlex lets two clients log onto the radio simultaneously so that each can independently control the radio (they do share the one transmitter).
Morning Len, Thank you. Just running 2.210 was an adventure. have re-installed the 3.5.8. happy camper now. You are just north of me. looks like rain today. need to go cover the pellet grill before it starts.
Great! I'm glad that solved it.
If you have 2.10 or 3.5.8 installed, it does run the cleanup script.
BTW, 2.10 and 3.5.8 are the EXACT same software other than 3.5.8 allows you to us MultiFlex and SmartControl.
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
