The Configurer – N1MM Logger Plus
https://n1mmwp.hamdocs.com/setup/the-configurer/#ptt-delayThe Configurer is our name for the tabbed dialog that appears when you click Config on the Entry Window top menu, and then choose Configure Ports, Mode Control, Audio, Other. The Configurer has many tabs with program settings influencing all aspects of the behavior of the program.
