Bias fixed to mode
Steve London
I am using a (new) PGXL with a non-Flex radio, using CAT control. The bias (AB/AAB) seems to be locked to the radio mode, and can not be changed from the utility or the touch screen. Is this the correct operation ?
Steve, N2IC
Yes. AAB on voice modes sets VDD at 52 volts and bias to 4 amps. This gives better IMD performance.
For single tone modes (CW, FT8, etc) you can enable MEffA. This will set bias to 2 amps and adjust VDD on the fly to maximize efficiency and reduce heat.
Steve, just curious, what OEM radio are you using ?
(this is not related to your question, just curious)
FTDX101D and TS-590S
Would you mind answering the questions on this thread please.
It would really help out others.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
