PGXL and TGXL being used with OEM HF (non-Flex) radios
Hi All
We are doing an informal survey to see what OEM (non-Flex) radio you are using with your PGXL.
Can you take a moment and comment by replying:
- What OEM radio
- What CAT mode did you select (or, are you using RFsense)
- Your TX Delay (it should be 20ms or better)
- Your TGXL version
- Your operating style (FT8, SSB, CW, Dxing, Contesting, etc)
- Any other comments
thanks
Again, comment in this thread please.
Hi
I am using a Kenwood TS-890s and Flex 6600
The Flex is on port A of the PGXL and Kenwood on port B I have a 1x3 TGXL also
so it is on port A for both radios with manual coax switch to select the different radio I want to use
I use Cat for the Kenwood 890 and of course Lan control on Flex
PGXL controls the band information on the TGXL
Because I have a 1x3 TGXL I have to disable the Flex on port A and enable Kenwood in settings of
TGXL when using Kenwood and enable Flex when going back to Flex 6600
TX delay is set for 30 ms on Kenwood 30 ms on Flex
TGXL version is 1.1.20 PGXL ver is 3.7.32
I operate SSB some CW with Kenwood and Flex SSB and some FT-8
I operate some contests with both Radios
Ray WB0HHM1 -
SO2R Flex Station: Meastro/6600, PGXL, TGXL, 2x8 AG
- Tx Delay 30ms
- Ethernet cables
SO2R OEM Radio: IC7610, PGXL, TGXL, 2x8 AG
- TGXL (CAT)
- 2x2 coax switch to swap the 6600 A&B ports with the 7610 antenna ports (to the PGXL)
- PGXL (SENSE)
- PTT lines to TGXL - Manual PTT switch for routing SO2R_TX1 and SO2R_TX2 to PGXL, Icom only provides one PTT line for both antennas.
- PTT lines to TGXL
- Tx Delay 30ms
FT8, CW, SSB
Latest TGXL and PGXL versions
Jeff - AK0DX
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThanks both!
BTW, the recommended TX Delay is 30ms and that is something that is set in your radio.
For those that don't know what TXD is, it delays the RF by 30ms before sending it. This allows all the RF devices downstream to move from RX to TX. 20ms might be enough but you should be fine at 30ms. And, we doubt you'll even notice the difference.
For those using a FlexRadio exciter, there is a much more robust communication between the radio and the downstream devices. The radio actually talks to other devices to see if they are ready to transmit.
- What OEM radio -- ICOM 7610
- What CAT mode -- CI-V on B
- Your TX Delay -- 20 ms
- Your PGXL version -- 3.7.32
- Your operating style (FT8, SSB, CW, Dxing, Contesting, etc) -- ALL
- Love my PGXL
- W8ASA Ken
- 694 The Flea Market
- 357 FLEX-8000 Signature Series
