PGXL Utility Reconnecting...
Hello, I'm using as normal my 6600 with SmartSDR v3.4.23 and my PGXL with PGXL Utility FW3.7.32 up to yesterday all operating normally.
This morning I started both my 6600 PGXL and I usually operate my PGXL with the Utility but apparently is not connecting and I only get the Utility with a message Reconnecting...
I already power off and re-started my PC but still the same, Reconnecting...
6600 PGXL working OK (RX/TX).
Any ideas why apparently is not connecting with the Utility ?
Thank You
Hello @Juan TG9AJR -- I have been experiencing this same exact issue recently. Under the previous firmware and now again on the latest. Last time I reset the PGXL back to factory defaults and wrestled to get the static IP reconnected. I don't want to do that again. I have placed a video of what is happening on my WeTransfer service (20Mb .mov file can not be attached on this discussion thread apparently.)
One thing I have noted is that I can still access the PGXL from SmartSDR for Windows and Mac. I can set it to standby or operate... I just can't see it with the Utility anymore.
Any ideas from the community? I will submit a follow up ticket to support. We are two people reporting this now... so I'm guessing it is being seen by others too?
Thank you.
The Genius devices, PG-XL included, only allow three TCP-connected devices.
You mention other connections....perhaps you have reached the three limit.
Be sure to count the Flex radio as one of the three connections.
Alan. WA9WUD
Hello @John WA7UAR thanks for your reply and for the information as well, that it is interesting that is happening to you as well and I'm sure too others as well.
As you mentioned it both the PGXL and 6600 work OK but the PGXL Utility is useless and yes I also like to see my transmit display on the Utility but under the Reconnecting... it does not work at all.
This is the very first time it happens to me, never before even with previous FW versions.
All do I have to say that yesterday after several hours of both the 6600 and PGXL to be ON and transmitting, suddenly out of the blue and without doing anything the PGXL it did connect (finally) to the Utility and seem as normal...will see how it goes today.
@Alan as far as TCP-connected devices I only have my 6600 the PGXL to a network switch and nothing else (in my case).
Juan TG9AJR
Update and without a clue but as mentioned before yesterday after several hours of been Reconnecting... suddenly it did connect and today just as normal no issues connecting the PGXL with the PGXL Utility.
[FYI] Not necessarily means solved or answered.
Hi All
Can you all make sure you reach out to 4O3A about this? You can email them at support@4o3a.com.
They need to be aware of it and they are the ones that do the software. They don't monitor this forum.
Here is an update...
Today I learned that the static IP address of my PGXL had been inadvertintly assigned by my network administrator to another device on the network that I use. It eventually came to light when other administrators "higher up the food change" tracked down the issue.
As soon as I was given a new IP address then the "Reconnecting..." error went away and I am now able to access my PGXL using its utility program.
Here is the ticket that I reported to Flex support that is now closed:
So... lesson learned... if the PGXL or TGXL are constantly "Reconnecting..." then look for a duplicate IP assignment somewhere on your network. This would also explain why the issue came and went... the "other device" was sometimes turned off and so would not cause the problem until it came back on again.
3 -
BTW I did sent a couple of emails (the same) 4O3A support about that issue, so far I had never heard back from them.
The Reconnecting message means that the Application is not able to communicate with the PGXL
Some of the root causes are:
- Different IP address
- Network issues resulting in a loss of communications
- Bad LAN cable resulting in a loss of communications (yes, this does happen)
In your case, you must be on a work (commercial) setup. That is not the situation for most home operators since we are usually our own admin.
For others at home, this is why running DHCP all the time is much more reliable. The DHCP server will not reassign an IP address if it is in use. As well, for home networks, the PGXL application can 'hear' the PGXL broadcasting its location when you first start the application. If it doesn't they you have a communications loss assuming the PGXL is actually turned on.
I had this same problem for a very long time -- it was easy to ignor, because the PGXL reconnect only lasted for a couple of seconds and then reconnected. Experimenting (I have a lot of different network switch types and brands), I found that all of my network switches caused the problem, some made it a lot worse. I ended up changing the network switch, where my Flex-6600, -6700, TGXL, PGXL, PC (dedicated to Flex station), and 2x8 Antenna Genius are all connected, to a 16-port version of the network switch that Mike uses (tp-link TL-SG1016DE)... (Mike uses same switch only 24-port version). I've had this network switch in use for about 2 months, and have yet to see the "reconnecting" PGXL app screen notification...YMMV. Switch cost me $85 + tax on Amazon.
I have noticed on occasion where the PGXL is trying to connect when running the PGXL utility, however, it never does and it keeps retrying. I leave the PGXL on rather than shutting it down when I am not using it. In order to get the PGXL to connect I have to power down the amp and then turn it back on using the switch on the back of the amp. I use static IP addresses for all the radio equipment, however, I wonder if that is the way to go. I understand the differences between static and dhcp addresses. I have a group of addresses setup in my router designated as static. Any thoughts?
Don - kx9q
Hi All, I had this yesterday also. When transmitting the network went to red and got a reconnecting. My PGXL was 3 days from new did a factory reset and it now works fine . So i would suggest trying that.0
@Jonoears When you get the reconnecting message, it is related to a network loss of communications and then it recovers. Often, this is due to RF in the CAT cables, which can happen. In fact, it happens more thanmost people are aware.
I can’t really see how a reset would resolve this, but let us know what happens in the future.
Sorry Mike just seen this reply from a earlier post! I have just logged another issue which is basically same. How can I remove the RF I have been putting filters on my network cables and I have a 1:1 balun where my antenna comes into the shack?0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
