Issues with Slice Master using Smart Link
Peter66
Member ✭
Smart Link works well on my Flex 6600. I tried the New Version of Slice Master 6000 v 11 g. Slice Master connected to the Radio, but didn/t open Wsjtx automaticly.
I tried per Hand ,pushing the Wsjtx Button , but nothing happend.
Any Idea?
73 Peter
DK5PH
Any Idea?
73 Peter
DK5PH
You may want to look at the SlicerMaster .INI file and see if it has the correct location for WSJT.
Also, you need to make sure that DAX is running and that the slice you are using has an assigned DAX channel.
Hallo Mike
The Location of Wsjtx is correct . DAX is running ,the DAX control Panel with the RX Slices are blue and Streaming.
Slice Master reported:
Connected to Radio
Warning:Audio Channel is not enabelt in Dax Control Panel dax=1 Slice=a. So
But Dax Control Panel is still streaming +Slice a
Peter0 -
You might consider emailing the author of SliceMaster.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
