Issues with Slice Master using Smart Link
Peter66
Peter66 Member ✭
edited August 2023 in Third-Party Software
Smart Link works well on my Flex 6600. I tried the New Version of Slice Master 6000 v 11 g. Slice Master connected to the Radio, but didn/t open Wsjtx automaticly.
I tried per Hand ,pushing the Wsjtx Button , but nothing happend.
Any Idea?
73 Peter
DK5PH
    You may want to look at the SlicerMaster .INI file and see if it has the correct location for WSJT.
    Also, you need to make sure that DAX is running and that the slice you are using has an assigned DAX channel.
  • Peter66
    Peter66 Member ✭
    Hallo Mike
    The Location of Wsjtx is correct . DAX is running ,the DAX control Panel with the RX Slices are blue and Streaming.
    Slice Master reported:
    Connected to Radio
    Warning:Audio Channel is not enabelt in Dax Control Panel dax=1 Slice=a. So
    But Dax Control Panel is still streaming +Slice a
    Peter
    You might consider emailing the author of SliceMaster.
