Profil Manager do not save all settings !!!
in picture 1 you will se that I made all settings as I need it when I do EME on 144mhz ( I use DIV to create 2 reciver on the same qrg) I save this profile in the manager..... but when I recall the profile there is missing my RX:A on slice:A and also the DAX:2 channel on slice:D
picture 2 show after a recall of the profile ....
73" OZ1CT Ben
Nice idea! Diversity for Faraday Rotation off the moon, Horizontal and Vertical polarization.
But I do not know what is wrong with the Profile Manager.
GL,
de Bill, NE1B
HI Bill
Yes it is to cure the Faraday Rotation off the moon, Horizontal and Vertical polarization and it works :-)
but every time I change mode whit the manager I have to remeber to switch on the A:RX and B:DAX-2
There must be a Bug in the way they save the settings ???
73" OZ1CT Ben
None of this has Ever worked reliably...
Profiles are at best crude. Often their unpredictable actions have disastrous effects on hardware.
Ron, WV4P
-1 -
Then I just hope that a software engineer from Flexradio read this message 😉
73" oz1ct Ben
Try setting up the two different slices in two different panadapters.
This will allow the logic to assign different RX antennas to each slice.
As it is, with both slices in the same panadapter, the radio is trying to assign them both to the same RX input.
To avoid much of this, I use the memories in frstack. It’s a free download, and its memories save many more parameters than the flex profiles or memories. I don’t operate without it.
Hi John
Why can the maneger save all ?? It rember your microphone settings 🤔 it would be great if it save all, so you don't have to install a " non-flexradio-software " ...
Hi Kenn
The problem with 2 slice is you can't get them to track the vfo .. A=B
Ben
If you want Slice A to track Slice B, you will need to run FRStack at the same time.
Hi Mike
I Don't want to run FRStack...I just want to get my Smartsdr 3.4.24 to save all my settings in the "Profile-manager"
as you see at my first post I can save the profile but I can't recall it as it "lose" some info !!!
there must be a bug in the software in Smartsdr... maybe try a "support ticket" ???
Sorry if I mis-understood your post.
What settings are lost? Can you be more specific?
In Section 18 of the SmartSDR Manual, it does show what settings are saved and if it is by a Global Profile, Mic Profile or Transmit Profile.
If you can pass that on, we can get it to engineering.
Persistence remembers these settings:
Global Profiles (not auto saved)
Mic Profiles - auto saved
TX Profiles - auto saved
HI Mike
try to look at the start of m thread...otherwise it is here:
trying to setup my Flex- f-6600 for adaptive RX on 144mhz EME using DIV. (using 2 transverter)
Slice: A I get RX:A and DAX:1
Slice: D I get RX:B and DAX:2
then I save this in the Profile Manager" as "144mhz-EME", if I then recall the "144mhz-EME" profile
it reload and then on Slice: A RX: A and on Slice: D, DAX: 2 is missing ?????
using here:
Smartsdr 3.4.24
PC: i7 - 16gb ram 1tb SSD
Win-10 64 bit
73" OZ1CT Ben
Hi Mike
Have you try it out ????
73" Ben
Hi @Bent
Please open a support ticket for this.
HI Mike
ok I wil open one...and hope it will be fixede in of the next release of SmartSDR ;-)
73" OZ1CT Ben
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
