Lost connection to Power Genius Utility
Good Morning
I got the stream deck to work with my Flex 6400M and they I immediatly lost the connection to the power genius utility, it still connects to the SmartCat.
Has anyone had any issues with this or have a solution.
I did a reinstall of the Power Genius Utility and it did not fix it. I have not changed any ip addresses and they are all static.
Thank You
Chuck Bigbie N5ANY
Usually, when this happens, you have an IP conflict or too many devices connected to the Power Genius XL.
Make sure there are no other applications trying to connect.
did a factory reset and got a new IP address and it all works. Funny it just stopped working when I got the stream deck to work?
Thanks for the reply
73's N5ANY Chuck
If I remember correctly, there is a limitation of only 4 IP connections to the PGXL. The radio takes one, the Application takes one. FRStack takes one (for the StreamDeck).
Was there anything else?
Wow, that could be it, I have frstack, radio, applicatioin, smart sdr, stream deck! Live and learn.
- 650 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
