PTT (with foot switch) not working on a 6500
Alexandr
Member ✭
I use the FLEX 6500 with a USB microphone. When I press the MOX or VOX button, the transceiver switches to transmit mode, and everything works fine. However, when I press the foot switch, the transceiver switches to TX mode, but there is no actual transmission. I've tried doing a RESET and even upgraded SMARTSDR to 3.4.24, but it didn't help. Can you suggest what I can do to fix this issue?
This is working as designed.
When you use a Foot switch plugged into the back of the radio, the Mic must be connected to the radio.
- 391 Community Topics
- 665 The Flea Market
- 169 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
