PTT (with foot switch) not working on a 6500
Alexandr
Member ✭
I use the FLEX 6500 with a USB microphone. When I press the MOX or VOX button, the transceiver switches to transmit mode, and everything works fine. However, when I press the foot switch, the transceiver switches to TX mode, but there is no actual transmission. I've tried doing a RESET and even upgraded SMARTSDR to 3.4.24, but it didn't help. Can you suggest what I can do to fix this issue?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis is working as designed.
When you use a Foot switch plugged into the back of the radio, the Mic must be connected to the radio.
- 688 The Flea Market
- 105 Aurora
