NodeRed and Monitoring your Bandwidth
Mike-VA3MW
Thanks Kyle AA0Z for great NodeRed flow to monitoring your bandwidth.
This can be important if you need to have performance discussions with your ISP.
  • AA1SS
    AA1SS Member ✭✭✭
    Trying to load speedtest into the pallet and I get this error . . . Any Ideas???
    023-06-22T12:01:05.630Z Install : node-red-contrib-speedtest 1.1.0
    2023-06-22T12:01:05.948Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-speedtest@1.1.0
    2023-06-22T12:01:07.125Z [err] npm WARN config production Use `--omit=dev` instead.
    2023-06-22T12:01:12.022Z [err] npm
    2023-06-22T12:01:12.022Z [err]  WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
    2023-06-22T12:01:16.761Z [err] npm ERR! code 1
    2023-06-22T12:01:16.761Z [err] npm ERR! path C:\Users\ww1ss\.node-red\node_modules\lzma-native
    2023-06-22T12:01:16.763Z [err] npm ERR!
    2023-06-22T12:01:16.763Z [err]  command failed
    2023-06-22T12:01:16.763Z [err] npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-pre-gyp install --fallback-to-build && rimraf build
    2023-06-22T12:01:16.763Z [err] ERR! Building the projects in this solution one at a time. To enable parallel build, please add the "-m" switch.
    2023-06-22T12:01:16.763Z [err] npm ERR!   build
    2023-06-22T12:01:16.764Z [err] ERR!   Microsoft (R) Library Manager Version 14.36.32535.0
    2023-06-22T12:01:16.764Z [err] npm ERR!   Copyright (C) Microsoft Corporation.  All rights reserved.
    2023-06-22T12:01:16.764Z [err] npm ERR!      Creating library C:\Users\ww1ss\.node-red\node_modules\lzma-native\deps\bin_x86-64\lzma.lib and object C:\Users\ww1ss\.node-red\node_modules\lzma-native\deps\bin_x86-64\lzma.exp
    2023-06-22T12:01:16.764Z [err] npm ERR!   deploy
    2023-06-22T12:01:16.764Z [err] npm ERR!           1 file(s) copied.
    2023-06-22T12:01:16.764Z [err] npm ERR! C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets(248,5): warning MSB8065: Custom build for item "..\deps\doc\liblzma.def" succeeded, but specified output "c:\users\ww1ss\.node-red\node_modules\lzma-native\build" has not been created. This may cause incremental build to work incorrectly. [C:\Users\ww1ss\.node-red\node_modules\lzma-native\build\liblzma.vcxproj]
    2023-06-22T12:01:16.764Z [err] ERR!   util.cpp
    2023-06-22T12:01:16.764Z [err] npm ERR! C:\Users\ww1ss\AppData\Local\node-gyp\Cache\18.16.0\include\node\v8.h(39,10): fatal  error C1083: Cannot open include file: 'v8-locker.h': No such file or directory [C:\Users\ww1ss\.node-red\node_modules\lzma-native\build\lzma_native.vcxproj]
  • AA1SS
    AA1SS Member ✭✭✭
    2023-06-22T12:01:16.764Z [err] npm ERR! Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node --module_name=lzma_native --module_path=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
    2023-06-22T12:01:16.764Z [err]  ERR! node-pre-gyp info it worked if it ends with ok
    2023-06-22T12:01:16.764Z [err]  ERR! node-pre-gyp info using node-pre-gyp@0.11.0
    2023-06-22T12:01:16.764Z [err]  node-pre-gyp info using node@18.16.0 | win32 | x64
    2023-06-22T12:01:16.764Z [err]  node-pre-gyp WARN Using needle for node-pre-gyp https download
    2023-06-22T12:01:16.764Z [err]  node-pre-gyp info check checked for "C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node" (not found)
    2023-06-22T12:01:16.764Z [err] npm ERR! node-pre-gyp http GET https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
    2023-06-22T12:01:16.764Z [err] npm ERR! node-pre-gyp http 404 https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
    2023-06-22T12:01:16.764Z [err]  ERR! node-pre-gyp WARN Tried to download(404): https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
    2023-06-22T12:01:16.764Z [err]  node-pre-gyp WARN Pre-built binaries not found for lzma-native@4.0.6 and node@18.16.0 (node-v108 ABI, unknown) (falling back to source compile with node-gyp)
    2023-06-22T12:01:16.764Z [err]  node-pre-gyp http 404 status code downloading tarball https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
    2023-06-22T12:01:16.764Z [err] ERR! gyp info it worked if it ends with ok
    2023-06-22T12:01:16.764Z [err] ERR! gyp info using node-gyp@9.3.1
    2023-06-22T12:01:16.764Z [err]  ERR! gyp info using node@18.16.0 | win32 | x64
    2023-06-22T12:01:16.764Z [err]  ERR! gyp info ok
    2023-06-22T12:01:16.764Z [err] npm ERR! gyp info using node-gyp@9.3.1
    2023-06-22T12:01:16.764Z [err] npm ERR! gyp info using node@18.16.0 | win32 | x64
    2023-06-22T12:01:16.764Z [err] ERR! gyp info find Python using Python version 3.10.11 found at "C:\Users\ww1ss\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe"
    2023-06-22T12:01:16.764Z [err]  gyp info find VS using VS2022 (17.6.33815.320) found at:
    2023-06-22T12:01:16.764Z [err] npm ERR! gyp info find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
  • AA1SS
    AA1SS Member ✭✭✭
    2023-06-22T12:01:16.764Z [err]  ERR! gyp info find VS run with --verbose for detailed information
    2023-06-22T12:01:16.764Z [err]  gyp info spawn C:\Users\ww1ss\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe
    2023-06-22T12:01:16.764Z [err] npm ERR! gyp info spawn args [
    2023-06-22T12:01:16.764Z [err] npm ERR! gyp info spawn args   'C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   'binding.gyp',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '-f',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   'msvs',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '-I',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   'C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\build\\config.gypi',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   '-I',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   'C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   'C:\\Users\\ww1ss\\AppData\\Local\\node-gyp\\Cache\\18.16.0\\include\\node\\common.gypi',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   '-Dlibrary=shared_library',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   '-Dvisibility=default',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   '-Dnode_root_dir=C:\\Users\\ww1ss\\AppData\\Local\\node-gyp\\Cache\\18.16.0',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   '-Dnode_gyp_dir=C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   '-Dnode_lib_file=C:\\\\Users\\\\ww1ss\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\18.16.0\\\\<(target_arch)\\\\node.lib',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '-Dmodule_root_dir=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   '--depth=.',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   '--no-parallel',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '--generator-output',
    2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args   'C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\build',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '-Goutput_dir=.'
    2023-06-22T12:01:16.765Z [err]  ERR! gyp info spawn args ]
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info ok
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info it worked if it ends with ok
    2023-06-22T12:01:16.765Z [err] ERR! gyp info using node-gyp@9.3.1
    2023-06-22T12:01:16.765Z [err]  gyp info using node@18.16.0 | win32 | x64
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe
    2023-06-22T12:01:16.765Z [err]  ERR! gyp info spawn args [
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   'build/binding.sln',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   '/clp:Verbosity=minimal',
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args   '/nologo',
    2023-06-22T12:01:16.765Z [err]  gyp info spawn args   '/p:Configuration=Release;Platform=x64'
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args ]
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! build error
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe` failed with exit code: 1
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack     at ChildProcess.onExit (C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:203:23)
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! System Windows_NT 10.0.22621
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "build" "--fallback-to-build" "--module=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\binding-v4.0.6-node-v108-win32-x64\\lzma_native.node" "--module_name=lzma_native" "--module_path=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\binding-v4.0.6-node-v108-win32-x64" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v108"
    2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! cwd C:\Users\ww1ss\.node-red\node_modules\lzma-native
    2023-06-22T12:01:16.766Z [err]  gyp ERR! node -v v18.16.0
    2023-06-22T12:01:16.766Z [err] npm ERR! gyp ERR! node-gyp -v v9.3.1
    2023-06-22T12:01:16.766Z [err] npm ERR! gyp ERR! not ok
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! build error
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node --module_name=lzma_native --module_path=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (C:\Users\ww1ss\.node-red\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
  • AA1SS
    AA1SS Member ✭✭✭
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1091:16)
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! System Windows_NT 10.0.22621
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\ww1ss\\.node-red\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! cwd C:\Users\ww1ss\.node-red\node_modules\lzma-native
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! node -v v18.16.0
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! not ok
    2023-06-22T12:01:16.767Z [err]
    2023-06-22T12:01:16.767Z [err] npm ERR! A complete log of this run can be found in: C:\Users\ww1ss\AppData\Local\npm-cache\_logs\2023-06-22T12_01_07_068Z-debug-0.log
    2023-06-22T12:01:16.788Z rc=1
    @AA0Z any ideas?
  • AA0Z
    AA0Z Member ✭✭
    Looks like the speedtest API changed and the owner of the speedtest node is not updating so I would say this flow is broken until we can find a new speedtest node to substitute.
  • AA0Z
    AA0Z Member ✭✭
    OK, for those of you playing at home, I'll have a fix out soon. Looks like the speedtest team has a CLI command you can install, so I'll need to update the flow. Thanks to some peeps in the Node Red for Ham Radio Groups i/o for showing me some info to get this updated!
    ....more to come....watch this space or my YouTube channel for an update to this flow.
    https://www.youtube.com/@aa0z
  • Bob W4PG
    Bob W4PG Member ✭✭
    Wondering if this is still an issue? I cannot add speedtest either, getting a lengthy error message similar to AA1SS above. I downloaded Kyle's flow from groups.io but missing the speedtest node. Anyone have it working?
    .............Bob W4PG
  • AA0Z
    AA0Z Member ✭✭
    edited January 2025
    You might need to add speedtest manually via the npm manager. Make sure you have npm installed too.
    sudo apt-get install npm
    npm install --save speedtest-net
    If it gives errors, look in the error log to figure out what is wrong. Type the error into Google and someone has probably figured out a work around.
    Also, make sure your Node JS version is at least V12. If you have an older version of Node Red or haven't updated in a while, your version of NodeJS is probably the issue.
  • OllyBe
    OllyBe Member
    No problem at all
