NodeRed and Monitoring your Bandwidth
Thanks Kyle AA0Z for great NodeRed flow to monitoring your bandwidth.
This can be important if you need to have performance discussions with your ISP.
Trying to load speedtest into the pallet and I get this error . . . Any Ideas???
023-06-22T12:01:05.630Z Install : node-red-contrib-speedtest 1.1.0
2023-06-22T12:01:05.948Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-speedtest@1.1.0
2023-06-22T12:01:07.125Z [err] npm WARN config production Use `--omit=dev` instead.
2023-06-22T12:01:12.022Z [err] npm
2023-06-22T12:01:12.022Z [err] WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2023-06-22T12:01:16.761Z [err] npm ERR! code 1
2023-06-22T12:01:16.761Z [err] npm ERR! path C:\Users\ww1ss\.node-red\node_modules\lzma-native
2023-06-22T12:01:16.763Z [err] npm ERR!
2023-06-22T12:01:16.763Z [err] command failed
2023-06-22T12:01:16.763Z [err] npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-pre-gyp install --fallback-to-build && rimraf build
2023-06-22T12:01:16.763Z [err] ERR! Building the projects in this solution one at a time. To enable parallel build, please add the "-m" switch.
2023-06-22T12:01:16.763Z [err] npm ERR! build
2023-06-22T12:01:16.764Z [err] ERR! Microsoft (R) Library Manager Version 14.36.32535.0
2023-06-22T12:01:16.764Z [err] npm ERR! Copyright (C) Microsoft Corporation. All rights reserved.
2023-06-22T12:01:16.764Z [err] npm ERR! Creating library C:\Users\ww1ss\.node-red\node_modules\lzma-native\deps\bin_x86-64\lzma.lib and object C:\Users\ww1ss\.node-red\node_modules\lzma-native\deps\bin_x86-64\lzma.exp
2023-06-22T12:01:16.764Z [err] npm ERR! deploy
2023-06-22T12:01:16.764Z [err] npm ERR! 1 file(s) copied.
2023-06-22T12:01:16.764Z [err] npm ERR! C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Microsoft\VC\v170\Microsoft.CppCommon.targets(248,5): warning MSB8065: Custom build for item "..\deps\doc\liblzma.def" succeeded, but specified output "c:\users\ww1ss\.node-red\node_modules\lzma-native\build" has not been created. This may cause incremental build to work incorrectly. [C:\Users\ww1ss\.node-red\node_modules\lzma-native\build\liblzma.vcxproj]
2023-06-22T12:01:16.764Z [err] ERR! util.cpp
2023-06-22T12:01:16.764Z [err] npm ERR! C:\Users\ww1ss\AppData\Local\node-gyp\Cache\18.16.0\include\node\v8.h(39,10): fatal error C1083: Cannot open include file: 'v8-locker.h': No such file or directory [C:\Users\ww1ss\.node-red\node_modules\lzma-native\build\lzma_native.vcxproj]
2023-06-22T12:01:16.764Z [err] npm ERR! Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node --module_name=lzma_native --module_path=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
2023-06-22T12:01:16.764Z [err] ERR! node-pre-gyp info it worked if it ends with ok
2023-06-22T12:01:16.764Z [err] ERR! node-pre-gyp info using node-pre-gyp@0.11.0
2023-06-22T12:01:16.764Z [err] node-pre-gyp info using node@18.16.0 | win32 | x64
2023-06-22T12:01:16.764Z [err] node-pre-gyp WARN Using needle for node-pre-gyp https download
2023-06-22T12:01:16.764Z [err] node-pre-gyp info check checked for "C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node" (not found)
2023-06-22T12:01:16.764Z [err] npm ERR! node-pre-gyp http GET https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
2023-06-22T12:01:16.764Z [err] npm ERR! node-pre-gyp http 404 https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
2023-06-22T12:01:16.764Z [err] ERR! node-pre-gyp WARN Tried to download(404): https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
2023-06-22T12:01:16.764Z [err] node-pre-gyp WARN Pre-built binaries not found for lzma-native@4.0.6 and node@18.16.0 (node-v108 ABI, unknown) (falling back to source compile with node-gyp)
2023-06-22T12:01:16.764Z [err] node-pre-gyp http 404 status code downloading tarball https://node-pre-gyp.addaleax.net/lzma-native/lzma_native-v4.0.6-node-v108-win32-x64.tar.gz
2023-06-22T12:01:16.764Z [err] ERR! gyp info it worked if it ends with ok
2023-06-22T12:01:16.764Z [err] ERR! gyp info using node-gyp@9.3.1
2023-06-22T12:01:16.764Z [err] ERR! gyp info using node@18.16.0 | win32 | x64
2023-06-22T12:01:16.764Z [err] ERR! gyp info ok
2023-06-22T12:01:16.764Z [err] npm ERR! gyp info using node-gyp@9.3.1
2023-06-22T12:01:16.764Z [err] npm ERR! gyp info using node@18.16.0 | win32 | x64
2023-06-22T12:01:16.764Z [err] ERR! gyp info find Python using Python version 3.10.11 found at "C:\Users\ww1ss\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe"
2023-06-22T12:01:16.764Z [err] gyp info find VS using VS2022 (17.6.33815.320) found at:
2023-06-22T12:01:16.764Z [err] npm ERR! gyp info find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"
2023-06-22T12:01:16.764Z [err] ERR! gyp info find VS run with --verbose for detailed information
2023-06-22T12:01:16.764Z [err] gyp info spawn C:\Users\ww1ss\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe
2023-06-22T12:01:16.764Z [err] npm ERR! gyp info spawn args [
2023-06-22T12:01:16.764Z [err] npm ERR! gyp info spawn args 'C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
2023-06-22T12:01:16.765Z [err] gyp info spawn args 'binding.gyp',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '-f',
2023-06-22T12:01:16.765Z [err] gyp info spawn args 'msvs',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '-I',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args 'C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\build\\config.gypi',
2023-06-22T12:01:16.765Z [err] gyp info spawn args '-I',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args 'C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args 'C:\\Users\\ww1ss\\AppData\\Local\\node-gyp\\Cache\\18.16.0\\include\\node\\common.gypi',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args '-Dlibrary=shared_library',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args '-Dvisibility=default',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args '-Dnode_root_dir=C:\\Users\\ww1ss\\AppData\\Local\\node-gyp\\Cache\\18.16.0',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args '-Dnode_gyp_dir=C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp',
2023-06-22T12:01:16.765Z [err] gyp info spawn args '-Dnode_lib_file=C:\\\\Users\\\\ww1ss\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\18.16.0\\\\<(target_arch)\\\\node.lib',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '-Dmodule_root_dir=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '-Dnode_engine=v8',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args '--depth=.',
2023-06-22T12:01:16.765Z [err] gyp info spawn args '--no-parallel',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '--generator-output',
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args 'C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\build',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '-Goutput_dir=.'
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args ]
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info ok
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info it worked if it ends with ok
2023-06-22T12:01:16.765Z [err] ERR! gyp info using node-gyp@9.3.1
2023-06-22T12:01:16.765Z [err] gyp info using node@18.16.0 | win32 | x64
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe
2023-06-22T12:01:16.765Z [err] ERR! gyp info spawn args [
2023-06-22T12:01:16.765Z [err] gyp info spawn args 'build/binding.sln',
2023-06-22T12:01:16.765Z [err] gyp info spawn args '/clp:Verbosity=minimal',
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args '/nologo',
2023-06-22T12:01:16.765Z [err] gyp info spawn args '/p:Configuration=Release;Platform=x64'
2023-06-22T12:01:16.765Z [err] npm ERR! gyp info spawn args ]
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! build error
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\MSBuild\Current\Bin\MSBuild.exe` failed with exit code: 1
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack at ChildProcess.onExit (C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:203:23)
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! System Windows_NT 10.0.22621
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\ww1ss\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "build" "--fallback-to-build" "--module=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\binding-v4.0.6-node-v108-win32-x64\\lzma_native.node" "--module_name=lzma_native" "--module_path=C:\\Users\\ww1ss\\.node-red\\node_modules\\lzma-native\\binding-v4.0.6-node-v108-win32-x64" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v108"
2023-06-22T12:01:16.765Z [err] npm ERR! gyp ERR! cwd C:\Users\ww1ss\.node-red\node_modules\lzma-native
2023-06-22T12:01:16.766Z [err] gyp ERR! node -v v18.16.0
2023-06-22T12:01:16.766Z [err] npm ERR! gyp ERR! node-gyp -v v9.3.1
2023-06-22T12:01:16.766Z [err] npm ERR! gyp ERR! not ok
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! build error
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Users\ww1ss\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64\lzma_native.node --module_name=lzma_native --module_path=C:\Users\ww1ss\.node-red\node_modules\lzma-native\binding-v4.0.6-node-v108-win32-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v108' (1)
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.<anonymous> (C:\Users\ww1ss\.node-red\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.emit (node:events:513:28)
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1091:16)
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:302:5)
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! System Windows_NT 10.0.22621
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\ww1ss\\.node-red\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! cwd C:\Users\ww1ss\.node-red\node_modules\lzma-native
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! node -v v18.16.0
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! node-pre-gyp -v v0.11.0
2023-06-22T12:01:16.766Z [err] npm ERR! node-pre-gyp ERR! not ok
2023-06-22T12:01:16.767Z [err]
2023-06-22T12:01:16.767Z [err] npm ERR! A complete log of this run can be found in: C:\Users\ww1ss\AppData\Local\npm-cache\_logs\2023-06-22T12_01_07_068Z-debug-0.log
2023-06-22T12:01:16.788Z rc=1
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@AA0Z any ideas?
Looks like the speedtest API changed and the owner of the speedtest node is not updating so I would say this flow is broken until we can find a new speedtest node to substitute.
OK, for those of you playing at home, I'll have a fix out soon. Looks like the speedtest team has a CLI command you can install, so I'll need to update the flow. Thanks to some peeps in the Node Red for Ham Radio Groups i/o for showing me some info to get this updated!
....more to come....watch this space or my YouTube channel for an update to this flow.
Wondering if this is still an issue? I cannot add speedtest either, getting a lengthy error message similar to AA1SS above. I downloaded Kyle's flow from groups.io but missing the speedtest node. Anyone have it working?
.............Bob W4PG
You might need to add speedtest manually via the npm manager. Make sure you have npm installed too.
sudo apt-get install npm
npm install --save speedtest-net
If it gives errors, look in the error log to figure out what is wrong. Type the error into Google and someone has probably figured out a work around.
Also, make sure your Node JS version is at least V12. If you have an older version of Node Red or haven't updated in a while, your version of NodeJS is probably the issue.
No problem at all0
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
