Add the Tuner Genius PTT OUT to the Band Settings panel.
I recently added a Tuner Genius XL to my shack with a Flex 6600 transceiver and a Gemini DX1200 linear amplifier. I was using the RCA TX1 output as the PTT for the amplifier so that I could have the amplifier PTT and "exciter" RF power out set to a lower drive level by a profile selection. Going back to a barefoot profile would just not key the amp but at higher power.
After inserting the TGXL into the line I had to move the PTT for the amplifier to the PTT OUT of the TGXL. This was the only way to prevent the linear from keying during a TGXL tune cycle.
It also meant that could no longer use the RCA TX1 output as an option in Band Settings to prevent me from keying the amplifier accidentally at full power from the 6600. At least, I haven't found a way to do that.
I described this problem and an interlock solution that I am going to build here.
Feature Request: In a perfect world, there would be an additional column of checkboxes for the PTT OUT on the TGXL in the Band Settings of SmartSDR so that I could selectively key the PTT OUT (to the amplifier) from a profile and still exclude it from a Tune cycle of the TGXL. Another option would be to add a setting to the TGXL software to mirror one of the existing RCA TX# outputs so I could use it as before.
Danny
I put a SPST in the amp keyline. It sits next to my keyboard. I just need to remember to switch it off when the TGXL tunes.
For that matter I could manually put the amp in standby mode. I still want control from SmartSDR.
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
