Best connection/utilization of 6500 with AG8x2 + TGXL (SO2R) + PGXL
Thanks!
I would just use ANT 1 to A all the way through.
You could use ANT 2 as well, but there is no advantage.
But, yes, upgrade to a 6600 when you can. The 6700 is not being built anymore, but I guess you could locate a used one.
If you want to trade in your 6500, we can work with you on that.
> 73
Roughly how much would I get for my 6500 on trade towards a 6600?0 -
Please reach out to us at hams@flexradio.com or by utilizing the link above.
We will get back to you pretty quickly.
> 73
OK. I used the link.0 -
I have 2 6700 flex radio with power genius xl and tuner genius and antenna genius all so2r. do i need to hookup both flex radios or
one radio on ant 1 and 2 to port a and b?0 -
I never received a response.
You can have the 6500 ant 1 to PG XL A and Ant 2 to PG XL B.
All slices will have to use the same RX antenna but you can have Slice A set to use one antenna for TX and slice B use a different TX antenna.
To be able to receive on two different slices on different antennas you would need a 6600 or 6700. Not sure why sales has not reached out to you. Maybe check your spam folder. Send an e-mail to sales@flex-radio.com and someone should return your email.
Dave DeCoons wo2x
Flex Presale Support
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
