Mox- PTT remote
Ben van Schoor
Member ✭
I use my 6600M remote, I control the Mox/PTT with the mouse or Vox but would like to control it with a real switch or with the stream deck, does anyone know a solution how I can do this remotely on the PC? 73 PA3BVS
Best Answers
See if this is what you’re looking for…
73…
https://community.flexradio.com/discussion/comment/20243764#Comment_20243764
Remote PTT is fully supported by SmartSDR/SmartCAT.
in SmartCAT, create a link between a real RS232 port (or USB/RS232 adapter) on your PC and SmartSDR.
Connect your switch to the ground (pin 5 for a 9-pin connector) and RTS (pin 7) or DTR (pin 4) accordingly to the SmartCAT configuration and you are in business.
Use FRSTACKS and then connect a awitch via comport ( or usb com dongle ) to switch . You an also use a key from the keyboard etc.
many thanks for the reactions, 73 PA3BVS0
There is more discussion here:
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
