Mox- PTT remote
I use my 6600M remote, I control the Mox/PTT with the mouse or Vox but would like to control it with a real switch or with the stream deck, does anyone know a solution how I can do this remotely on the PC? 73 PA3BVS
Welcome!
Best Answers
  • Member ✭✭✭
    Answer ✓
  • Member ✭✭✭
    Answer ✓
    Remote PTT is fully supported by SmartSDR/SmartCAT.
    in SmartCAT, create a link between a real RS232 port (or USB/RS232 adapter) on your PC and SmartSDR.
    Connect your switch to the ground (pin 5 for a 9-pin connector) and RTS (pin 7) or DTR (pin 4) accordingly to the SmartCAT configuration and you are in business.
  • Member ✭✭✭
    Use FRSTACKS and then connect a awitch via comport ( or usb com dongle ) to switch . You an also use a key from the keyboard etc.
  • many thanks for the reactions, 73 PA3BVS
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    There is more discussion here:
    Physical PTT for Remote SmartSDR
