Can't upgrade Maestro to 3.4.24
I recently upgraded my 6700 to 3.4.24 and then tried to upgrade my Maestro. Unfortunately, when I try to connect my Maestro (running 3.3.32), while under "Info" for my 6700, it sees that the 6700 is now running 3.4.24, it doesn't offer that as an upgrade for the Maestro.
What am I missing?
Rick, W7YP
Is your Maestro connected to the internet or directly to the 6700?
This can happen if you are directly connected to the radio with the Maestro, or, for some reason the Maestro is not able to call the FlexRadio maintenance server.
Thank you for the quick response, Mike!
It's connected to the Internet (See attached "Info" display from my Maestro's screen). I don't get any kind of error message from the Maestro. If I launch SmartSDR on my Windows 10 PC, I can remotely disconnect SmartSDR from my Maestro.
I'm puzzled. I've never had an upgrade issue before.
Rick, W7YP
I fell victim to this once before. Think the fix was cycling the wifi on the Maestro and or the Ethernet connection.
Ive got same problem here, upgraded 6500, 2 days ago. Want to upgrade Maestro V1 now. Message says
'Connected to Ethernet, Maestro server unavailable'
Have rebooted Maestro couple of times, doesnt help
Dont know if its related but for over a week now, Ive had intermittent trouble trying to get into the Flexradio.com website. When I can get into it, some of the pictures are missing. Was working earlier but now not, and this is what i get
Dont know if its related, but sure would like to get to the bottom of it.
Thats with Edge, but Chrome and Firefox doing same thing
I dont seem to have any problems with any other websites
I think the problem here is now fixed. I can get Flexradio.com and community on mobile data on iphone but not on wifi on iphone or pc. I changed dns servers on pc and also on iphone and can get into flexradio.com and community and the Maestro is now found the server and has updated to 3.4.24
Hope this helps others
Sounds like your original DNS servers were not updating.
Thank you everyone for your suggestions. While not having changed anything on my network configuration, I decided to once again try to update my Maestro and this time it worked. Not once, during the past several days, have I had any DNS lookup problems. All new URLs opened fine in every browser I tried. But this still feels like a DNS lookup glitch of some kind.
Before composing this message, I decided to browse the FlexRadio website and discovered that I could not open the Community forum. The browser would complain that it couldn't locate the site. Every other part of the FlexRadio website worked just fine. When I tried to ping community.flexradio.com, it complained that it could not get the IP address of that site. I tried a couple more times and it finally resolved the IP address.
I was then able to get into the Community Forum to compose and send this message.
I'm going to chalk it up to some kind of weird Internet glitch that hopefully does not return.
Rick, W7YP
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 976 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
