SSDR 3.4.24 - Receive Audio Dropping Out
I installed SSDR 3.4.24 yesterday and it worked OK until last evening when the receive audio stopped working. This happens on PC Audio and when using the powered speakers directly. A reboot of SSDR fixes the problem... until it happens again. Is there something I should do to better isolate the cause of this problem?
I created a support ticket for you.
Thank you, but I believe it may not be needed now. I went through the Memory menu and found several SSB "rows" had the Squelch selected. Of course, I unselected (cleared the check marks) those and all is working well. The only thing that concerns me is how those became selected, so I will keep an eye on that.
Glad you figured it out. 73
Update: Discussed this with Ken W. and did another cold boot with a minor change in the procedure from what I had done before (unselected Preferences when saving/loading profiles). So far, so good. Rebuilt my memory list and everything is pretty much the way I want it. The only thing yet to work on is my 10-M repeater frequencies and a couple of minor changes.
Thanks to Ken and the Flex crew. :)
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
