SSDR 3.4.24 - Receive Audio Dropping Out
I installed SSDR 3.4.24 yesterday and it worked OK until last evening when the receive audio stopped working. This happens on PC Audio and when using the powered speakers directly. A reboot of SSDR fixes the problem... until it happens again. Is there something I should do to better isolate the cause of this problem?
    I created a support ticket for you.
  • Jerry W2TXB
    Jerry W2TXB Member ✭✭
    Thank you, but I believe it may not be needed now. I went through the Memory menu and found several SSB "rows" had the Squelch selected. Of course, I unselected (cleared the check marks) those and all is working well. The only thing that concerns me is how those became selected, so I will keep an eye on that.
    Glad you figured it out. 73
  • Jerry W2TXB
    Update: Discussed this with Ken W. and did another cold boot with a minor change in the procedure from what I had done before (unselected Preferences when saving/loading profiles). So far, so good. Rebuilt my memory list and everything is pretty much the way I want it. The only thing yet to work on is my 10-M repeater frequencies and a couple of minor changes.
    Thanks to Ken and the Flex crew. :)
