ATU and antenna matching
PFSOD
I have a 6400 w/ATU. Should I be able to successfully tune to a G5RV Jr which has a 300 Ohm lead? I have that lead running to the 6400 with 75' of 50 ohm coax. I'm just not sure it's working. Also, I lost my audio again.
Out of curiosity, I suggest an SWR meter. The internal tuner will transform a 3:1 to a more useable value.
If the tuner stops with sucess , and you get good reports.. all is well..
If the tuner cannot tune sucessfully or you get bad reports.. something is wrong and needs investigation.
The ATU on a 5400 will tune an SWR of about 3:1 or less.
Since G5RV's are originally designed for 20M try that band first. It might tune as its impedance should be around the right amount.
However, it is likely you'll need a broader range Antenna Tuner such as an LDG to tune that antenna.
If you have any readings from an antenna analyzer, that would be helpful.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
