ATU and antenna matching
PFSOD
PFSOD Member ✭✭
I have a 6400 w/ATU. Should I be able to successfully tune to a G5RV Jr which has a 300 Ohm lead? I have that lead running to the 6400 with 75' of 50 ohm coax. I'm just not sure it's working. Also, I lost my audio again.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Out of curiosity, I suggest an SWR meter. The internal tuner will transform a 3:1 to a more useable value.
  • Ha Gei
    Ha Gei Member ✭✭✭
    If the tuner stops with sucess , and you get good reports.. all is well..
    If the tuner cannot tune sucessfully or you get bad reports.. something is wrong and needs investigation.
    The ATU on a 5400 will tune an SWR of about 3:1 or less.
    Since G5RV's are originally designed for 20M try that band first. It might tune as its impedance should be around the right amount.
    However, it is likely you'll need a broader range Antenna Tuner such as an LDG to tune that antenna.
    If you have any readings from an antenna analyzer, that would be helpful.
