FRSTack3 can't see the 6400 that's on the same LAN and same subnet
I am using FRSTack3 with SmartLINK in Win 11 for one of my remotes and it works just fine.
I have a second remote 6400 and running that one on the LAN side via WireGuard VPN. The radio works fine for voice and data and it's also in Windows 11. <-- not using SmartLINK
However, after installing the latest FRStacks3 (3.1.36.70) and starting it in admin mode. it never sees the radio. This FLEX6400 is on the same LAN and subnet as the computer.
Reading the first post, it recommends that I edit the FRStack3.exe.config file. I can access the file and edit it, but I can't save it. It says that I don't have permission. I have RWMD admin rights on the remote computer and I am able to make changes like registry edits, file updates, etc.
- Are they referring to my admin rights on this computer? (I could have messed up)
- What am I missing?
It sounds like your Windows Firewall is blocking the communications. You might want to look there first.
It isn't an Admin rights issue.
I'll check again as that's one of the first places I looked in. I'll also see if there are any ports that need to be open
SOLVED - The firewall has two FRSTack3 entries.
- One was "Private" and "Public" while the other entry was only "private".
- I changed that to "ptivate"and "public" and now FRSTack3 works :-)
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
