Continual quick flashing blue logo on Flex 6400
HI. You could do a lot worse than send an equiry to Tim at Flex.
I am not sure that his listing below answers your question??..........
July 2013 edited December 2016
The Power LED color and blink state indicate the operational state of the radio hardware SOLID BRIGHT RED = Transmitting on PA SOLID ORANGE = Transmitting on XVTR port with low power SOLID DIM RED = Transmit engaged, interlocks not resolved (will not emit RF) SOLID PURPLE = Updating software FLASHING YELLOW = GPS in warmup SOLID YELLOW = GPS in holdover (lost satellites) SHORT FLASH BLUE = GPS locking LONG FLASH BLUE = GPS in hold phase mode SOLID BLUE = GPS locked SOLID GREEN = Receive SOLID AMBER = Radio off, GPS powered for stability FLASHING RED "S" = Flashing a Morse "S" in Red indicates boot failure OFF = Radio off, oscillators off NOTE: The FLEX-6700R does not have the Transmit Indicator (Solid RED)
Hi Mike,
I made brief reference to this in my question. I don't understand why it would suddenly just want to lock onto GPS when I was merely using it to receive. And why did it kick itself off the server and not allow me to access it at all. If nothing else, I would think the reset would allow access again. Right now, the 6400 is a "flashing blue" paper weight.0 -
I would submit a help desk ticket.
If you have a GPSDO installed, it is constantly updating regardless if you are in TX or RX.
The GPSDO isn't installed. This whole "quick flashing blue" thing just decided to occur. Apparently, no rhyme or reason.0
I believe the OP stated that it is the "Waves" logo flashing.
Everyone seems to be referring to the power button...
Hi.
Yes, the Waves logo is continually flashing blue.
Joe0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
