Flex 6600M Meastro v3.4.21.14056 Unhandled error has occurred. HRESULT: 0x8889000F
I had been away for a few days and powered up the 6600M this morning and got this error: "Meastro v3.4.21.14056 Unhandled error has occurred. HRESULT: 0x8889000F". Tried restart three times and got the same error. Radio works fine with SmartSDR. Meastro was working fine the last time I used it. I saw another thread that talked about a display reset, but thoiught I would post this first to see if it is the same error. Screenshot of the error is attached.
Brad, N4PYI
After performing a factory reset of the radio, all is well. I imported my profiles that I saved beforehand, and everything is good.
Brad, N4PYI
Hi @Brad Adams (N4PYI) ,
You havent had the problem back? I just had my 2nd crash like that and hate to do a factory reset for nothing ...
Thanks in advance.
Rick
DU6/PE1NSQ
Hi
Maybe this is corrected in SSDR v 3.4.23?
SMART-9236: https://www.flexradio.com/software/smartsdr-v3-4-23/
Netas Ameba0 -
@rickd Please open a support ticket so we can get it resolved for you if a restart of the Maestro did not resolve it.
Hi Netas,
Yeah Im running that version ... I didnt had it on previous versions..
Thanks for the suggestion though
Rick
Ok, thanks Mike ...
Let me open a support ticket for this then ...
Restart was ok 1 time, then next time i got the same issue (6400M).
Im currently running from my computer and have no issues there ...
Rick
Ok i was running 21 ... 21 - 23 not much difference right? :)
anyway, i just updated to 3.4.23 and so far its good ... If it happens again I will open a support ticket
Thanks guys,
Rick
DU6/PE1NSQ
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
