Auto-Connect does not work 6400M
w4ram
Member ✭
My 6400M is connected to internet via ethernet, the auto connect option is enabled, however the 6400M does not go through the auto connect process, is necessary do that manually.
When I open the Advanced Network Settings I see the following message:
“Auto-start failed: Problem connecting to the radio”
The ethernet icon in the bottom left corner show radio is connected to internet
Running 3.4.21.14056
I am using Maestro (connected same home network), I turn on it after 6400M is up.
Asking for your advice to fix this issue. Thank you
V/R
Al Mesa
V/R
Al Mesa
I opened a support case for you.
Thank you Mike!
V/R
Al0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
