Auto-Connect does not work 6400M
w4ram
w4ram Member
edited March 2023 in FLEX-6000 Signature Series
My 6400M is connected to internet via ethernet, the auto connect option is enabled, however the 6400M does not go through the auto connect process, is necessary do that manually.
When I open the Advanced Network Settings I see the following message:
“Auto-start failed: Problem connecting to the radio”
The ethernet icon in the bottom left corner show radio is connected to internet
Running 3.4.21.14056
I am using Maestro (connected same home network), I turn on it after 6400M is up.
Asking for your advice to fix this issue. Thank you
V/R
Al Mesa
    I opened a support case for you.
  • w4ram
    w4ram Member
    Thank you Mike!
    V/R
    Al
