Troubleshooting Remote Laptop Setup on Flex 6600 for Gaming Laptop
judywatson
Member ✭
Hello everyone,
I am reaching out to the forum with regards to an issue I am currently experiencing in setting up my gaming laptop [https://www.lenovo.com/ca/en/d/gaming-laptops] remotely on my Flex 6600. I have tried a few different methods, but so far, I have not been successful in getting the remote setup to work as intended.
I have followed the instructions provided by the manufacturer and ensured that all software and firmware are up to date. However, whenever I try to connect remotely, I am not able to get the audio or video to work correctly, and the connection is unstable.
I am using a high-speed internet connection with plenty of bandwidth, so I do not believe that the issue lies there. I have also tried different settings for the audio and video, but none of them have solved the problem.
I would appreciate any advice or suggestions that the forum members may have regarding this issue. I am open to trying new methods or tools to get the remote setup to work as intended.
Thank you in advance for your help.
Best regards,
Judy
Best regards,
Judy
Hi Judy
There are a number of issues that need to look further on:
- What is the bandwidth of the internet of your upload/download?
- You might want to run some buffer bloat tests (you can google buffer bloat). This can affect your audio quality
- Based on what you are saying, it sounds like you you are dropping data packets
- Is there any WiFi involved?
- You said that it isn't a bandwidth issue, but that is an assumption. How do you know for sure? This is something that needs to be confirmed 100% since it is such a key part of the solution.
That is just some ideas of areas that we need to look deeper into.
Judy, how are you connecting remotely? Is it with smartlink?
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
