Unhandled error has occured
Using a 6600M with the latest firmware 3.4.21.14056 with absolutely no problems until today. Haven't used the 6600m for about 3 days due to illness and when I booted the radio up a few minutes I got this error message. " MAESTRO (v3.4.21.14056) An Unhandled Error Has Occured. Exception From HRESULT: 0x8889000F" Anyone have any ideas.
    If you have a screen shot of the UHE, can you send it to us via the support system.
    We need more data to help isolate it.
  • Dennis Little
    Dennis Little Member ✭✭
    Hey Mike, thanks for the quick reply however after sending in HelpDesk ticket last night I did a (for lack of a better term) a display reset by using a prior procedure I had gotten by pressing the A Step button and the F1 button then powered down for 2 minutes, unplugged pwr cable for 30 seconds then plugged pwr cable back in, waited 2 minutes then powered the radio back up by holding down the power button until it lit up in white and it reset the display. Then uploaded my profiles that I had saved and everything is now working as it should. Please disregard this helpdesk ticket as everything working GREAT. Thank again for your quick response.
    OK... please let them know. They hate it when I touch support calls! :)
