v3.4.21 issue with Maestro A display ok now
After install v3.4.21 on my Maestro A, I get this display, no waterfall, no signal at all in panadapter. Confirmed SW version 3.4.21.14056. I've rebooted the Maestro several times, even rebooted the 6700. SmartSDR works fine thru windows client. I should mention that I use the Maestro daily and v3.3.33 was fine. I may need a support ticket for this. I was thinking of downgrading the Maestro back to v3.3.33 then redoing the upgrade.
UPDATE: After downgrading to v3.3.33, then re-upgrading to v3.4.21, the display is back as normal. I see the panadapter with waterfall as it should. Must have been a glitch during the initial upgrade between reboots of the Maestro.
No ticket necessary.
that is usually due to a Vita 49 packet loss issue.
That is interesting as that is not something we saw in all the Alpha testing we did. If you get it again, please open a support ticket.
I am having a similar problem Mike. After upgrading, I ended up with two displays. One waterfall and another tuning. Can you point me to the operational documentation for Maestro, please?
I am having the same problem. Cannot connect properly with Maestro or ipad SDR via Smartlink. All ok via local wifi connection.
Smartlink log in looks ok and connected and some controls kind of work but no spectrum display or audio.
Have reverted to v3.3.33 where it also would not work and reinstalled 3.4.21 again, done a factory reset of radio but problem persists. On Maestro I see exactly same screen as Mike VE3CKO.
set up is 6500, Maestro, PC all connected via network switch which is connected back to Router. Software 3.4.21.
It did work ok a few weeks ago when last used but before latest updates.
any ideas of what to try next?
Mal G3PDH
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
