changed router now i can not connect remotely
i was using an amplifi alien wireless router. it is connected directly to the wall jack from the ISP. i run cat6 cables to the flexradio running the latest version software. and i run a cat 6 to the laptop. it works locally and remotely. occasionally the router will lock up, probably from RF in the shack. i switched the router to a:
TP-Link ER605 V2 Omada Gigabit VPN Router
it works fine from the ham shack and seems to have eliminated the router locking up.
now i can not open the radio remotely from another location.
when i click on the SDR radio remotely it shows the correct radio and it is green. however it has a popup that say "can't connect to the radio, try again.
any suggestions, it is probably some setting in the router not letting me in.
George B
W4SXZ
George,
Are you sure you have done the proper port forwarding setup in this router ?
Harry
i did not have to do port forwarding with the amplifi alien router.
i did have to get the isp to give me a public IP.
so i have not tried port fowarding yet.
i have never set up a port forwarding.
thanks,
George B
w4sxz
Please walk through all the steps in Chapter 9 of the manual again and redo your SmartLink setup.
If that doesn't fix it, please open a support ticket.
mike,
thanks, i had to enable upnp.
new router solved all my issues.
thanks.
George B
W4SXZ 73
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
