Smart SDR MAC Version 2.2.21 Fixes Remote CW OPS
The new version of SSDR MAC installed on my MAC this AM. The developer identifies that this new release improves the CW Keyer in several ways, and improves the local sidetone.
Well, after hooking up paddles to my 6600 via USB directly into the MAC, the side tone sounds great and the paddles work perfectly allowing my CW fist timing to finally be accurate not make me sound like a lid.
More testing is needed, but I am optimistic that us CW OPS can finally work CW remote with paddles connected to the MAC and hear the generated side tone locally.
How is the Paddle connected to your Mac?2
Marcus has it outlined in the SmartSDR MAC documentation.
Connected via USB per the manual documentation. It's easy to do and works perfectly.
Found the information.
Thank you!
I don't know what I am missing here, have a MacBook Pro with a multiport docking, where I have FlexController, Yeti mic, ethernet etc connected. I can not get the paddle to work at all according to Marcus description.
Tried with 2 different cables, last one from FTDI, UT232R-200, it is found and selected in Tools/CW Keyer settings. Double checked the pins, even the PTT does not work for me. Any suggestions?0 -
Did you try connecting directly to the laptop without the multiport dock?
You will need a USB to USB-C adapter.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
