CW Skimmer Server
Does anyone suceeded in running Skimmer Server (NOT CW Skimmer) with Flex 6400.
There are a lot of messages in the forum, but no one says explicity that Skimmer Server can work with Flex and how.
I will appreciate an help in understanding if the integration:
- Panadapter 1 > used by the operator
- Panadapter 2 / DAX IQ Channel 2 > used by Skimmer Server
is feasible or not (I suspect not).
SDR-Bridge and Slice-Master are OK for CW Skimmer but do not address Skimmer Server (in my understanding).
Thanks, best 73
Alessandro i2sva
Alessandro
I have run 4 slices of CE Skimmer. What is the advantage or functionality of also running Skimmer Server ?
Bill W9JJB
Bill,
it work in the background, one instance can monitor more bands, you can connect via telnet using it instead of any dx cluster, getting the real spots and without having any windows/interface to manage...
Very useful in CW Contests; I use it together with a SDRplay RSPduo connected to a spare antenna, but I wanted to consolidate to Flex, if possible.
Alessandro
Alessandro,
Will the SDRplay provide multiple bands to the skimmer or just one band at a time?
Gary
Hi Gary,
SDRplay listen to one band at a time, but you can set SkimmmerServer to listen to more than one band and it will switch SDRplay every x time.
Alessandro
Thank you for the info.
Any actual resolutions to this? I am trying to setup the same scenario.
I think using SDC Skimmer will be much easier to set up. It was developed since this conversation happened over 2 years ago.
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 37 Aurora
- 947 Maestro
- 924 Genius Products
