One RX antenna for multi slices
AH0U
I have an RX loop but listen to two slices at a time. SSDR will not allow the loop to be selected on either slice.... only one port... any ideas on using one RX antenna on multi slices at a time??
Tnx, bc
OK.. here is a work around I found.... open a slice C and set it up the same as A..Close A ..open slice D and set it the same a slice B and close B.. now either RXA or RXB can be selected for either slice...
What model radio is this?
You should be able to use an RX antenna on many slices at the same time.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
