One RX antenna for multi slices
AH0U
I have an RX loop but listen to two slices at a time. SSDR will not allow the loop to be selected on either slice.... only one port... any ideas on using one RX antenna on multi slices at a time??
Tnx, bc
OK.. here is a work around I found.... open a slice C and set it up the same as A..Close A ..open slice D and set it the same a slice B and close B.. now either RXA or RXB can be selected for either slice...
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWhat model radio is this?
You should be able to use an RX antenna on many slices at the same time.
- 690 The Flea Market
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
