program a key on keyboard for MOX
Hi George,
I think that you may already have this. Click on the MOX button once to switch Windows focus. From then on, the space bar will toggle it on/off. Mine does. Problem is that it is not always hot. You must always insure that the focus remains with the MOX button. Hope this helps.
Bill AB7AA
@GeorgeBecknelL — kind of… the space bar will repeat the last command. So if your last command was to click on the MOX button and then click it again to toggle it off, then the space bar can be used to toggle MOX on and off… until you do something else manually. So that’s why I said “kind of” 😉
Hi George, What radio and what software are you using?
I have a Flex 6400 running SmartSDR V 3.3.33. If the SmartSDR control panel has the focus, pressing the spacebar toggles MOX on and off. I don't use this, as I can never be sure where I left the focus. It could be on the main screen, on the logging program, or elsewhere.
FRStack by W3II lets you assign hot keys to the MOX function that will work regardless of current focus. This is your best bet to get what you are looking for (assuming a Flex 6000 series radio).
using Flex 6400 latest version SmartSDR.
great comments above.
i will try the focus and see how it goes.
i will also look at FRStack.
thanks for the responses!
i was hoping i could program a F key to toggle MOX on and off.0 -
Hi George
You can do it with FRStack by assigning a hot key as Len said.
73, Mike
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
