One RX antenna for multi slices
AH0U
I have an RX loop but listen to two slices at a time. SSDR will not allow the loop to be selected on either slice.... only one port... any ideas on using one RX antenna on multi slices at a time??
Tnx, bc
OK.. here is a work around I found.... open a slice C and set it up the same as A..Close A ..open slice D and set it the same a slice B and close B.. now either RXA or RXB can be selected for either slice...
What model radio is this?
You should be able to use an RX antenna on many slices at the same time.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
