WSJT no longer works after 3.3.33
Loaded the new version 3.3.33 and that went well but now if I transmit in FT8 get a very broad and strange signal... using WSJT-X version 2.5.4 and SliceMaster.. this has worked well for a very long tine now it does not...I can click on TUNE in SSDR and it shows fine but tune in WSJT-X and it goes nuts... see screen shot attached.... Any ideas??? It does the same thing with JTDZ..I have tried a Factory reset and deleting and reinstalling software... The signal seems to "pulse" every second or so.. goes normal then this ... Ideas???
Please post a picture including the controls at the right, especially the LEVEL meter.
Since you have reset everything, that isn't part of the problem. In order to provide more insite, I need to see more of your configuration.
Anytime you have a transmit issue with any digital mode you need to review the audio levels first. That is the part that is missing from your picture.
My mail wont allow me to send a video but the wave from pulses so the one in this screen shot is different but you can see the whole setup... over driving was my first thought but that i not the case.
If you would like to see, I can Teamview so you get the whole experience
Please open a support ticket. This will require some more investigation.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
