WSJT no longer works after 3.3.33
AH0U
AH0U Member ✭✭
edited January 2023 in Third-Party Software
Loaded the new version 3.3.33 and that went well but now if I transmit in FT8 get a very broad and strange signal... using WSJT-X version 2.5.4 and SliceMaster.. this has worked well for a very long tine now it does not...I can click on TUNE in SSDR and it shows fine but tune in WSJT-X and it goes nuts... see screen shot attached.... Any ideas??? It does the same thing with JTDZ..I have tried a Factory reset and deleting and reinstalling software... The signal seems to "pulse" every second or so.. goes normal then this ... Ideas???
    Please post a picture including the controls at the right, especially the LEVEL meter.
    Since you have reset everything, that isn't part of the problem. In order to provide more insite, I need to see more of your configuration.
    Anytime you have a transmit issue with any digital mode you need to review the audio levels first. That is the part that is missing from your picture.
  • AH0U
    AH0U Member ✭✭
    My mail wont allow me to send a video but the wave from pulses so the one in this screen shot is different but you can see the whole setup... over driving was my first thought but that i not the case.
  • AH0U
    AH0U Member ✭✭
    If you would like to see, I can Teamview so you get the whole experience
    Please open a support ticket. This will require some more investigation.
